maxum1989
Mar 09, 2017Explorer II
Portable solar question
After researching for what seems like forever I have decided that I should try portable solar to see if solar is something I really need before I mount panels, wiring, controllers, etc in my two camping rigs. I figure I can try out the portable panel with both my rigs and then figure out if a roof mounted system on either or both is needed after that.
So, I think I have narrowed the portable panel search to this one:
https://www.amazon.com/ACOPOWER-Foldable-Controller-Battery-Charging/dp/B01MU4PGLQ
I debated long about a suitcase setup like above and a lighter folding setup using flexible panels. I was close on the flexible but it seems some say they don't perform and last as long as glass panels. Who knows, maybe it is still in play if I get some positive feedback on it.
This was the flexible kit I was considering:
https://www.amazon.com/ACOPOWER-Sunpower-Monocrystalline-Foldable-Controller/dp/B01M8LCDN2/ref=pd_day0_86_7?_encoding=UTF8&psc=1&refRID=TVT7ZSYKEYS7SEB2N6Y1
Yes, the above glass panel suitcase is one of the cheaper versions and doesn't come from one of the main name brands out there, but it has the Anderson connectors that I like and it doesn't break the bank. Another thing I would add would be one of these extension wires:
https://www.amazon.com/gp/product/B00HDKFQS6/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2X8N6V4HT8DJJ
Lets just say for argument sake that I would get 5 amps of charging from this panel is really good sun using it the way it came. Is someone able to tell me what that would drop to if I added the extension cable to the panel moving it further away from the batteries? I believe the extension wire is 10 gauge. Getting specifics of that is tough. Most people say its 10 or 8.
Next, with these portable panels the charge controller is mounted on the panels instead of being close to the batteries as preferred. Can someone tell me what the difference in amps of charging would happen if I re-wired this setup so the controller was close to the batteries?
Is it worth it enough to re-wire this thing?
