Almot wrote:
And again, MC4 is not a good choice for quick disconnect. Inconvenient in frequent use. They are OK for semi-permanent interconnects between the panels though.
Have you owned the suitcase? I do and you do not have to disconnect and reconnect wires after the first time... They stay connected with the alligator clips.. you clip them on the battery and voila...disconnect when done...roll up cables place back on side and then fold over the panel and snap shut. Then you put back in it's protective case....very easy....and no connecting or disconnect the mc4 connectors that come with it.....
