westend
Oct 22, 2013Explorer
BFL13 wrote:Dude, we've got to get you to migrate over to better wire and devices.:B I know the results you get with that aluminum clad battery cable are good but........oh, the humanity.:W
I use jumper cables to reach the portable panels set out on the ground. I have short lengths of #8 from the controller "array" terminals and from the panel junction boxes. To set up, I just use the clamps on the jumper cables.
I can add a second or third set of cables if I need longer. (like steal the 12ft set of #6 I keep in the truck)
I don't get any real voltage drop that matters with such heavy gauge wires either, which is nice.
http://www.princessauto.com/pal/en/Booster-Cables/20-ft-2-Gauge-Booster-Cables/8443723.p
Only thing is the red colour on the cable has turned pink from lying in the sun. :)
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
