Niner, you keep on using "amps" to be short for "amp hours" which is very confusing. You know better than that. :(
On daily hauls, I did a measuring trial (where I had to keep loads running all day so the amps didn't taper as battery SOC rose) using my Trimetric for the AH count.
May, sunny all day each trial, 49.3N, 130w panel got 8.2 Isc as rated panel aimed at high sun.
Flat- 56AH, Tilted up facing South all day- 70AH, Tilted up and turned toward sun three times a day SE, S, SW- 90AH
Of course you can't get that many AH when charging batteries because the batteries make the amps taper later in the day. But you can run loads and capture those amps and so get your AH haul if needed.
