mena661's avatar
mena661
Portable Solar
With all this talk of portable setups. It's got me thinking of one too. Here's the panels I'm interested in: Two 140W 12V panels. I saw where someone hinged a couple of panels together and put a handle on them. I might do a carry strap instead. So I don't have to take it down and put it up every day, maybe I can secure it to the top of the ladder. Not sure how to go about that. I can get a better picture tomorrow if needed.
  • I would purchase 4 of the 75 watt panels (Solar Blvd. 75 watt) from the same company that the OP links to. They weigh 15 lbs. each and would be much easier to handle.
    I have 2 panels mounted to the side of my coach, one is 125 watts and the other is 80 watts. The larger one is a bit difficult to get hooked back up to the side. The smaller one weighs about 15 lbs. and is no problem.
  • I find a 100 watt panel is the max weight I care to lift in and out of storage.
    For storage in a MH works great by building a slide in rack in just the top of one compartment. That compartment is still fully usable for storage after the panels are slid into grooves in the rack. I used a 4 ft 2x6 on each side w/ two 1 1/2" grooves in each one, and hung from the top
  • Hi mena,
    Use loose pin hinges. That way you need only lift 30 lbs (which is still more than enough in something that can catch the wind).
  • Almot's avatar
    Almot
    Explorer III
    60 lbs is a lot to lift and carry. Especially in large size.
  • Did you see RJsfishin's receiver mount for his modules? I don't remember in which thread it was pictured but I thought it was a pretty elegant way of mounting.
    Lifting two 30 lb modules that are joined by hinges to any appreciable height would not be a task I would like to do on a regular basis. I would rather have an easel on the ground or even one of BFL's turntables to use for securing them in position. Actually, I wouldn't want to do either, if I could park in half way decent sun. Roof mounting is a one-time shot and keeps the modules out of harm's way.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
