SoundGuy
Jun 20, 2017Explorer
johnm1 wrote:
- Using alligator clips to the batteries would be a pain in the backside for my setup. What kind of disconnect plug/connector should I use when I set up and take down the panels?
- I have the "Zamp Solar ready" outlet on the outside of the rv. Can I use that? Is it big enough wire for 100-160 watts of solar?
I'd install a vehicle end Bargman connector on the controller output and simply plug the trailer into it. That said, since your particular trailer already has a solar input connector on it I'd get the appropriate adapter and use that instead. K.I.S.S.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
