SoundGuy
Jun 20, 2017Explorer
johnm1 wrote:
I do like simple. Since the Zamp wiring is buried inside the walls, I'd most likely need to have the CC outside. Can I put it inside a waterproof box? I know the MPPT units generate a lot of heat, what about the PWM's?
Many of the moderate size (100 - 140 watt) folding suitcase style of portable panels I've seen have the controller mounted to the back side of the panels. Have to ask though - since solar is only effective in dry weather when the sun is out isn't your concern over rain moot as you'd have put the system away by then - no? :h
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
