red31
Jun 20, 2017Explorer
https://www.amazon.com/CES-Gauge-Quick-Disconnect-Harness/dp/B0057ZQJ12
not the best ^^^ connector
Put a controller with LCD inside with a short run to the batts.
From there, wire to crappy xamp plug for outside connection to panel(s).
Solarblvd 160w has crappy specs of 7A, no info on the controller, no wire from controller to batt, I consider it **** near FRAUD and they will not update or provide appropiate details. Good buy
https://www.solarblvd.com/products/solar-cynergy-160-watt-foldable-12-volt-solar-panel-2/
ecoworthy 100w folding comes with IP22 water proof controller, set pt 13.8v.
cut the cips off extend the wire add connector
http://www.eco-worthy.com/catalog/worthy-100w-foldable-polycrystalline-solar-suitcase-p-347.html
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
