marcsbigfoot20b
Jun 20, 2017Explorer
2oldman wrote:Lwiddis wrote:Yes.. you'd have to be careful. I don't think I see more than about 1 or 2 amps when it's moderately overcast. Heavy overcast almost nothing.
last shady campground, finally hit 90% at 5 pm but I was very careful with electrical use.
Heavy overcast is where 2 panels in series with mppt you can still charge batteries.
You have 40 volts, cut in half let's say by REALLY overcast skies so 20 volts, mppt will still charge at 14.5 and maximize the amps.
Also half the line loss helps when running 50-100 ft from panels to batts.
20 volt panel, overcast 10 volts...... NADA.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
