ktmrfs
Jun 21, 2017Explorer III
2oldman wrote:johnm1 wrote:Charging efficiency may be improved by connecting panels in series for higher voltage, considering you may be a distance away seeking sun.
My plan would be to move the CC to the storage bay or put it in a water proof plastic box type thing. Either way it'd be closer to the batteries for charging efficiency.
series only provides a benefit if you go for a MPPT controller. with a PWM controller, series connections or 24V panels is a serious drawback. you only get the current that the lowest rated panel can deliver.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
