ktmrfs
Jun 21, 2017Explorer III
johnm1 wrote:
You guys make my head spin with all this data and the more I read the more I ever so slightly understand and retain ... thank you for helping me with this.
With this new knowledge and the graph from red31, what happens when my rv is plugged into my running generator and the solar is still doing it's thing? Anything I need to be aware of or does it matter?
you shouldn't need to worry. what will happen is the generator will be charging the battery, or the charge controller and most likely provide more current capability than the panels can. so the charger will raise battery voltage, that will tell the solar controller to provide the needed current based on that voltage.
Basically, they will be operating in parallel, with most likely the generator being the master and the solar acting as a slave and follow the generator or charge controller if hooked to shore power.
they should coexist nicelym, at least all the systems I've seen do.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
