mike-s
Jun 22, 2017Explorer II
johnm1 wrote:Moving the CC won't change the efficiency one bit. Whether the voltage drop occurs in the wiring before or after the controller makes no difference.
If I need to move the CC for efficiency and since it's not waterproof, should I replace it with something better?
The only reason to move a PWM CC closer to the battery is if it supports temperature compensation and that will keep it from being at a significantly different temperature than the battery.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
