johnm1
Jun 22, 2017Explorer
Is the 0.6 - 1.2 volt drop going to kill my recharging ability with solar or is this where the CC comes in and somehow makes it work?
My wiring thoughts ...
- 50-100ft (1 direction) of 10 gauge wire with Anderson type connectors between the panels and the CC.
- CC within 5 ft of the battery (either inside the RV or inside a waterproof box).
- 10 gauge wire from CC to battery? I don't know what's biggest wire that I can use on the CC.
Keep in mind, I have a generator to (hopefully) do the heavy lifting charging every few days and (again hopefully) the solar will just hum along and finish it up.
edit: just saw red31's post.
Do I use the 17.8vpm instead of 12v for the drop calculations? If yes, then I'm guessing I'd be well above the 12-14+ volts needed?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
