ctilsie242's avatar
ctilsie242
Explorer II
Feb 22, 2017
Portable tire inflator recommendation?
For auto and trailer tires where the max PSI is 44 PSI or 60 PSI, what is a good, well built tire inflator that has a hose that screws onto the tire (I want it to screw onto the tire valve, because hunching over, trying to keep an adapter pressed onto the valve doesn't do my back much good.)
I have one I bought at AutoZone, but it definitely isn't something that I'd expect to last more than a year or so at best, so looking for something that can sit in the car until needed.
  • Vi air is what all the kids use to jack up their cars, I have one and it works great up to 100 psi; can buy on ebay or amazon
  • I'm not a fan of portable inflators without tanks. Compressing air causes moisture to condense and you can pump extra water into your tires - I've seen this happen. This is why the big compressors all have a drain/relief valve on the bottom of the tank. We carry a small(ish) compressor with a tank (Husky brand, I think). Main disadvantage is that it is 110 volt only... but we'll call roadside assistance for any issues with the fiver or DRW truck while travelling, anyway. I use the compressor to check and adjust pressures the evening before we hit the road each time - the morning of so tires are cold if we've traveled the previous day, too.
    Rob
  • Porter Cable has a nice inflator that does tires and inflatables. Runs off their 18v batteries or 12v outlet.
    I chose it because I had other PC brand tools, so swapping batteries between them was handy. The drill I use for my stabs and a lantern for extra light wherever.
  • DrewE's avatar
    DrewE
    Explorer III
    Most I've seen have locking tabs on the hoses which don't screw on but do stay on without being held. (Most air-through valve caps don't have threads on them anyway, but merely a sequence of ring grooves, so screw-on attachments aren't always the most useful anyhow.)
    I've never been particularly impressed by the inflators I've used; they're usually noisy and slow and seem poorly built. There may well be exceptions among ones I've not used.
    I have a nice little 120V compressor, a Fini AirBoss, for my motorhome and am quite pleased with it. This unit is about the size of a smallish suitcase and seems to be pretty nice for what it costs. Among other places, Lowes carries it sporadically, and Sears sells it to (rebranded as a Craftsman) at what is usually a higher price.
    Some here use a gas cylinder (usually CO2) and regulator setup, which might work out well for you.
