tenbear wrote:
CactusJoe wrote:
tenbear wrote:
CactusJoe wrote:
Well I disconnected the battery and now everything seems to work fine. No dimming, etc. Looks like I'll be replacing the converter.
Does this mean you are using the battery without the converter, or, the converter without the battery? If I read it correctly it seems like the battery is disconnected so it is running off the converter???
I disconnected the battery but left it plugged into shore power and everything seems to work fine now.
-JB
To me that indicates the battery, not the converter, is the problem. If you would, measure the converter output voltage and the disconnected battery voltage.
Voltage from the converter = 7v
Voltage from the disconnected battery = 12.3v
Should the 12v system still work with the battery disconnected while plugged into shore power?
-JB
