shane102's avatar
shane102
possible converter problem or ?
when hooked to shore power the battery monitor will not read full and the voltage is 12.2 on DC side. when the converter fan kicks on then the monitor will read full and the voltage is 14.36 on DC side. Also when the converter fan kicks on the lights will dim and when fan goes off the lights will come back full. I put new batteries in and new battery cables. yes the batteries are hooked up correctly (+ feed to one battery and - feed to other battery and in parallel + to + and - to - all grounds at batteries are clean and reattached. Any Ideas?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 21, 2025
