ford_truck_guy
May 07, 2017Nomad
wolfe10 wrote:
Two good questions.
Add to them:
Are you leaving the inverter on while driving?
If so, what 120 VAC things are on? Said another way, what is the draw on the batteries (in amps) times time driving. That will tell you how many amp-hrs you drained from the batteries.
Inverter is on, only 1 outlet is powered by it, that is for the residential fridge... I can drive from PA to FL with no battery issues last year, not the case now.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
