time2roll
May 07, 2017Nomad
OK is it really GELL or more likely AGM?
GELL is not that common and could be overcharging at 14.4 volts and they often have limited acceptance amps.
AGM charging at 14.4 is fine but is too high for float mentioned early in the post. High amperage charging is actually good with AGM.
I speculate the battery could have diminished capacity.
Best to post the exact battery make/model along with the converter model to verify the charging profile matches the battery.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
