dougrainer
Oct 02, 2018Nomad
Since you do not have a manometer. This is a quick test and usually will tell you the Regulator is failing. Turn on the Range burners. Turn on the Water heater and Furnace. Watch the Range burner flames. If they dwindle down or pulsate when the furnace and water heater start up and burners ignite and run, your regulator is BAD. Just 1 inch drop in LP pressure will cause loss of correct cooling. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
