wa8yxm
Dec 23, 2019Explorer III
Spade Cooley wrote:
I have a post regarding problems with my refrigerator and suspect I might have a power problem instead. This is my second post. I have a Sunset Trail 27 RB with one 12 volt battery. I see no specs in my owners manual. Should I get a marine battery or a deep cycle? The trailer is 9 years old and this could be its third battery.
I have a local Walmart. Don't we all?
Ok There are basically 3 or 4 types of batteries.
Regular Starting batteries have both Cranking amps and COLD cranking amps. What's the difference? 32 degrees Craning is 32 (and above) and CCA is at Zero (F) in both cases.
If it's not rated for COLD (Zero F) then it is a MARINE battery (Water freezes don't you know)
The above batteries should be kept 80-85 percent full MINIMUM and recharged quickly.
MARINE/deep cycle (note the case as I typed it) is really a MARINE but with lip service to deep cycle.. Change the Minimum SOC to say 75.
DEEP CYCLE (Golf Car batteries are DEEP CYCLE) can go down to 50% SOC and may well recover from an "OH ****! (Black out by poster) level discharge. Now the problem.. GC batteries come in basically 2 flavors GC-2 and GC-12 the 12 is a 12 volt but may not fit on your battery tray / box The GC-2's (takes 2 of 'em in series to make `12 volts) likewise may be a fit issue.
But if you can fit either of those (2 GC-2 or one GC-12) My recommendation is GO FOR IT.
But before you do that.. Get a good digital voltmeter and see how much voltage you got. Even 15 bucks at horrible (er, Harbor) Freight is a decent meter usually Most of them I've had calibrated well .
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
