JayNewbieRV's avatar
May 17, 2024
Solved
Potential engine overheating
I have a 2007 Winnebago view 23 and the temperature gauge gets pretty close to the red when going up hills.   I just bought this and it’s not even the middle of the summer yet, any recommendations to...
  • time2roll's avatar
    time2roll
    May 25, 2024
    Yes by all means if the engine is close to red the electric fan should be howling ferociously.
    Check the coolant level.  These heating issues can be a multitude of things but start with getting the fan running.
  • JDsdogs's avatar
    JDsdogs
    May 27, 2024
    Shows how old I am.  I don't think anything has had a fan clutch in decades. Maybe an electric heat sensor for the fan has failed? Of course he should check the coolant level and for material blocking radiator first, after that, taking it to a good shop with an analyzer should tell him if the fans heat sensor has failed or if the fan motor itself has died.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
