JC2
Aug 06, 2013Explorer
imgoin4it wrote:
I believe the bolts go all the way through the floor. I was going to take one of my seats out and while at the factory was told it is an easy but is a two person job. Someone has to be under the motor home to hold a wrench on the opposite end. I never went any farther
Going by what you and others have said, I will use the jacks and raise the coach enough to where I can crawl underneath and check after the chiropractor gets my back readjusted. Had one of those "DUH" moments when stepping off the curb several days ago.:R
Someone on another forum suggested using a blow dryer or heat gun on the low setting to soften the tile then use contact cement to try and reconnect the tile. Might try that also.:C
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
