landyacht318
Sep 11, 2017Explorer
My dell laptop requires a third wire for the Pin inside the barrell, or the battery will not charge, and it runs slowly.
When my DC/DC adapter stopped charging due to the third wire again breaking, I was able to splice on a powercord from another Dell power supply my neighbor had laying around.
When that Failed in the same manner, I tried to buy just another barrell connector/ wire for a Dell, but it was cheaper to buy an New AC/DC adapter and splice its cord onto my DC to DC adapter.
When the third wire on that connector failed, I took my knife to the barrell connector and resoldered the three wires onto it. I repotted the connector with Amazing Goop.
I also decided to run the wires to the barrell connector at a 90 degree angle to reduce strain on the connector.
Now I need to build that faraday cage for the DC to C adapter, so it stops knocking out channel 8( actual). An AC/DC adapter also knocks out this channel, and uses more wattage at the same time, and the inverter also takesout other TV channels
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
