dougrainer
Feb 15, 2015Nomad
Your problem is a COMMON one. The evidence is your BURNT spades on your 30 amp plug. You have been overloading your 30 amp RV. One BIG misconception people have is, IF you overload your RV 30 amp service, a Breaker will trip. NOT SO. When you have the BURNT spades (NOT corrosion as others have stated), that is where the resistance first builds up and that generates heat. Then you go to the Neutral BUSS that is burnt. When the Heat builds up from overload, the smallest wires heat up and then start to burn. You need to monitor your amp draw after you fixed the problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
