hiii98's avatar
hiii98
power convert how to diagnose.
I bought a camper and i noticed the fan on the power converter never turns on. put a tester on everything internally all the fuses internal and external...all good. However i noticed when i test the voltage on the negative cable it shows 12v, same with the positive cable. Any idea whats up? I remove a cable from battery (there are literally about 14 cables..this is on a semi)...and both sides show 0, put the cable back on...12v on both neg and positive again. Any advice? I assume the cables are bad and the unit is good?
  • jkwilson wrote:
    Measures 12V with the negative lead connected where? The main reading to be concerned with is from the negative to positive lead. If the negative lead is 12V above something, then the positive lead will be 24V above that point.
    if i put the black multimeter terminal to a metal ground and the other red on my negative cable i get 12v. i dont think i should be getting any volt on neg, only on the positive side i assume. Both pos and neg cable show 12v, also fan never spins on the converter.
  • Measures 12V with the negative lead connected where? The main reading to be concerned with is from the negative to positive lead. If the negative lead is 12V above something, then the positive lead will be 24V above that point.
  • it actually should show 12v...had to wiggle the tester.
    wont let me post the link! I guess copy and paste in browser if you want to see a pic, or just read my problem. No clue why i cant post pics or even a link...grrr
    https://ibb.co/K91pMW2
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
