gregfelty's avatar
gregfelty
Power converter issue
I currently have my travel trailer plugged into a 5000 W generator so that I can run a dehumidifier inside to dry some water damage. Apparently the power converter is not functioning as none of the 12 V features(lights, radio) are working.
Will I cause any further damage to the electrical system by leaving it plugged in?
FYI - 30 amp plug with dog bone plugged into 20 amp receptacle on generator.
Thanks
  • I see what you're saying. From past experience, this one does not require connection to battery in order to operate. I had it plugged in(without battery connection)last month at different location, and the lights, radio, outlets all worked.
  • gregfelty wrote:
    It is the WF-8900 series (WFCO). I don't see anything in the manual regarding an internal battery.
    Will have to grab a voltmeter and check it out tomorrow.
    The WFCO does not require a battery AFAIK. None of them have an internal battery, but some require that they be connected to a battery to work.
  • It is the WF-8900 series (WFCO). I don't see anything in the manual regarding an internal battery.
  • What converter is in your TT? Some of the older converters require a battery for them to work.
    If you turn off the circuit breaker to your converter you probably won't damage anything by leaving the TT plugged in
  • Battery is disconnected.
    Outlets are working. Have not had chance to test anything yet.
  • Is your battery disconnect switch off?
    Even if your converter isn't working, the battery should still supply power to the lights, etc, unless the battery is fully discharged.
  • Apparently doesn't tell us much. Need to know what voltage coming from converter and if battery ok .
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 04, 2025
