dryfly's avatar
dryfly
power converter replacement
It appears my WFCO WF-8965 converter has bit the dust. The supply puts out 13.7vdc until a load is applied, then output voltage drops to 3vdc. This is with no battery in the circuit, only on 120vac shore power.
I have seen several negative comments regarding WFCO converters. It appears that the Power Dynamics converters are much better quality, slightly less expensive, and are a direct swap for the comparable WFCO unit.
Anyone have any experience with this conversion?
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
