jgrimesExplorerJun 12, 2014Power ConverterMy new 36ft 5er has a WFCO WF-9865 65 amp power converter. It has an input of 105-130 VAC, 1260 W; output is 13.6 VOC. The charger is 3 nominal voltage output modes: 13.2 Vdc "float" mode, 13.6 Vdc "a...Show More
Old-BiscuitExplorer IIIJun 12, 2014Ain't broke why fix it........It's a 3 stage converter/charger.......meaning it will bulk charge a low battery then back off on charge voltage to maintain the battery.Use it...worry about replacement WHEN it doesn't work.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
Related ContentPower converterNo 12 Volt without converterPower converter friedNewbie power question80 amp converter and eu2000i
