jgrimesExplorerJun 12, 2014Power ConverterMy new 36ft 5er has a WFCO WF-9865 65 amp power converter. It has an input of 105-130 VAC, 1260 W; output is 13.6 VOC. The charger is 3 nominal voltage output modes: 13.2 Vdc "float" mode, 13.6 Vdc "a...Show More
time2rollNomadJun 12, 2014Do you ever charge from a generator? Verify voltage steadily rises to 14.4 volts at the fuse panel for superior charging and less generator time.Do you leave the RV plugged in for extended periods? Check voltage at the battery actually drops to 13.2 after a week of minimal or no use.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
Related ContentPower converterNo 12 Volt without converterPower converter friedNewbie power question80 amp converter and eu2000i
