My new 36ft 5er has a WFCO WF-9865 65 amp power converter. It has an input of 105-130 VAC, 1260 W; output is 13.6 VOC. The charger is 3 nominal voltage output modes: 13.2 Vdc "float" mode, 13.6 Vdc "a...
smkettner, yes, I do charge from a Honda 2000i generator at times. When you say to check the voltage at the fuse panel do I simply remove the cover plate and check the voltage by placing the electrodes of the voltmeter on the main breaker terminals - or do I do this at the battery terminals?
Yes, I do leave the unit plugged in for extended periods. I'll check to voltage as you suggested - have not done so in the past so I can't answer your question at this time.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
