jgrimes
Jun 12, 2014Explorer
Power Converter
My new 36ft 5er has a WFCO WF-9865 65 amp power converter. It has an input of 105-130 VAC, 1260 W; output is 13.6 VOC. The charger is 3 nominal voltage output modes: 13.2 Vdc "float" mode, 13.6 Vdc "a...
jgrimes wrote:
smkettner, yes, I do charge from a Honda 2000i generator at times. When you say to check the voltage at the fuse panel do I simply remove the cover plate and check the voltage by placing the electrodes of the voltmeter on the main breaker terminals - or do I do this at the battery terminals?
