wanderingaimles
Jun 20, 2020Explorer
Usually the problem your describing is on the ground side. As a quick check try using a jumper cable from the battery negative to a good ground location on the frame. it may save you some time.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
