JRMunn's avatar
JRMunn
Power Drain
Sorry this is so long.  I was lucky enough that all trailer systems seemed to be working for a couple of years (except for day and night shades), so I got out of the habit of checking in to the forum discussions.  Things seem to have changed.  But now I have a problem that I can't figure out, but someone else might have an answer.  Last week, when I used the trailer (a 2004 SunnyBrook Titan 5th wheel), I woke up to no AC power on the second morning.  The trailer batteries were okay, so I didn't even notice this until the coffee maker didn't work.  The trailer was plugged in to a solar power system, so I started there.  As best I could tell, the solar batteries weren't dead, but they wouldn't start the inverter, and the controller screen was blank.  I eventually got the system running, but the inverter showed a 400-watt load.  This load disappeared when I unplugged the trailer.  So, I turned off the inverter, left the solar system to recharge, and started a generator for the trailer.  The following night, I measured the voltage drop from using the heater while in bed.  The loss was not quite 1 volt (from about 13.7 to over 12.7) from two 100-amp AGM batteries in parallel, which calculates (crudely) to about 40 watts per hour.  So, I seem to have a 400-watt, continuous load from somewhere between the trailer plug and the trailer batteries.  400-watts for 24 hours comes to 3600 watts per day.  This is more than the solar panels produce through winter's fog, clouds, short days, and long nights, not counting my own use, which explains why the solar batteries were low.  All that I can find between the trailer input cord and batteries is a transfer switch and the power converter.  Is this a symptom of a dying power converter?  Can it be tested with the converter still installed?  Any thoughts would be appreciated.
  • ok so a few things I need some clarification on, you talked about getting the inverter going so you could make your coffee, but then you said you unpluged it.  were you pluged into shore power and trying to use your inverter at the same time?
    a 400 watt load on the inverter, could it be the converter breaker was on so it was trying to charge your batteries?  thats close to a 35 amp 12V output
    my auto transfer switch died two seasons ago, but I had it set up so shore power was one input and my inverter output was the second one, I don't use a genny.  so with mine I went to turn on mu inverter and I wasn't hearing the ATS change over and wasn't getting any 120V at all, but I also hade my converter power wired into the input shore power side of the ATS so there is no way my converter will start if I am not pluged in through the rv power cord.  if you are not wired up this way and the converter power still comes off the in put to the power center then you have to run off the braker.
    could it be a dying converter sure, easy test, just look up the testing voltages and procedure for your converter.  I know for most I have had it is a spicif voltage with no batteries hooke up.  it could be a few things, with out knowing exactly how its wired, I am just throwing a few things out there.  the ATS usaly is a easy one, just take the cover off see if it is obvioulsy burnt, then try to change over to the two different inputs and see if it actualy switches.
    • Grit_dog's avatar
      Grit_dog
      Navigator III
      Electrical gremlins / draws are sometimes difficult to figure out.
      You’ve done a pretty good job trying to describe the issue but not enough for me to understand your setup.
      You have effectively a residential solar power system that you’re powering the camper with but it’s only just a glorified battery bank that is supplyingDC power or is there an inverter and it’s effectively a shore power setup? AC power to the camper?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
