jdubya
May 06, 2018Explorer
Power Gear Slide-out System is failing
Whoa! I just hauled my Fleetwood Flair 2004 down for new tires, getting ready for a major trip. Got back and went to open the slides and 'nothing' - I can't find the controller for the slides. The book says its a Power Gear - it has two slides each with a single motor. The large one is accessible, but neither works. I was able to apply 12 vdc to the large motor and it turned out a couple of turns so I stopped and turned it back in. All fuses I can find are good and I checked all the wiring that I can find/get to.
Last time that I tried it was last fall when I stored it. I usually store it open, but this year I closed it.
I should probably mention that I have another electrical problem where 12 vdc is not reaching the switcher that runs the overhead panel's electronics such as the rear camera and the tv switcher. The camera lost power when the cable wore through and shorted things out. I didn't know about it until the camera quit, but the slides worked for several times in/out after that. I can't find anything wrong there either.
I see that others have experienced motor problems, but I cannot find any reason to suspect them. They usually do not just quit. This is affecting both slides. The one is under the bed and the other is a large one on the driver side. I exercised the big slide's motor, but I'm getting concerned because we have reservations starting Mon May 7
I cannot find a controller anywhere, all the fuses appear to be ok, the automatic levelers by the same company appear to work ok. The slides will not actuate with or without the levelers - I am usually able to operate them without the levelers.
The fuses for the 12 vdc are above the desk in the bedroom. Power is there but measures 10.6 vdc. All automotive fuses are in a cubby in the top of the front panel. All check out and measure 12.6 vdc (all measurements are sitting with engine off). The other main fuse box is in the engine compartment and has many fuses and some relays, also the cut-off solenoids. All of this stuff appears to be working, the engine starts and everything else appears to work except the two items mentioned.
There is a separate fuse box with huge fuses and some relays above the larger one. It also appears to be ok - all of the fuses check out and the voltage is 12.8 vdc within a few inches of the battery - which itself is brand new and starts the big vortec without hesitation. I have to have the engine running to get the levelers to operate, so I ran them but didn't recheck the voltages - the 10.6 is surprisingly low and I double-checked it.
I looked through all of these switches and fuses and I find no mention of slideouts though auto levelers are indicated.
Any suggestions?
Any suggestions?
