rockcandymounta
Jun 29, 2014Explorer
Power Inverter Fan
I bought my 2006 Springdale new. Under normal conditions, whenever I would turn on several interior lights, the cooling fan on my inverter would come on. I can understand that the inverter could probably run warmer with more power being drawn. The service panel is a WF8955AN w/plastic
I just brought the trailer home and de-winterized it. I noticed that as soon as I hooked shore power up, the fan at the service panel/inverter started to run. Nothing was turned on in the trailer. There are 6 circuit breakers that are switch controlled. They are labeled from top to bottom as Main (30Amp) AC (20Amp) Conv(15Amp) Recept (20Amp) Micro (20Amp) GFI (15Amp) and Water Heater (15Amp).
I have no idea what the one labeled Conv is for and the one labeled Recept, I am assuming is for the wall recepticles. The inverter is very cool to the touch so I wonder why the fan would be running with nothing turned on. Also, the fan is a bit noisy. It looks like a standard computer case fan. I could live with the fan running all the time if it was quieter. I just cant understand why the fan would run constantly. Any Ideas appreciated.
