MrWizard wrote:
That 6 amps is wrong, did you look at the back of the fridge and get the numbers of the plate on the compressor
My 7.5 cu ft apartment fridge draws approx 1amp at 120vac, that's 10+ amps into the inverter
But the start up surge aka lock rotor amps of the compressor is 10+ amps 120v, that's 100 amps start surge off battery power into into the inverter
6 amps might be the start surge, which would be very low ( I like that )
Running load will be less
Put the inverter close to the batteries, and run an extension cord to the fridge for the low amp 120v
I suspect the name plate lists the MAX amperage..
That most likely includes the defrost heaters.
The compressor should be 1A-1.5A run and startup surge would be somewhere around 9A-11A at 120V (that is what I measured on mine).
The defrost heater on mine is 250W but some fridges have higher wattage defrost heaters.
My setup I used a Tripplite PV1250, gives me lots of headroom for the startup surge and added bonus of a load sense power save feature which allows the inverter to turn on/off with the AC load.
I used 1/0 extra flex wire and 6ft counting both pos and neg wire..
The setup works very well and we are pleased with it.
Don't skimp on the inverter or the 12V wiring, skimping there will result in a lot of frustration on your part.
