dougrainer
Jul 31, 2021Nomad
There are a few areas for the fuses on a Midwest depending on the Model(They make about 12 models).
1. Under the drivers floorboard is the chassis battery. When you remove the covers to access the battery you will see various inline fuses that control cables between the Coach and Chassis battery. These are Midwest installed
2. Under the drivers seat on the side viewing from the open drivers door is a set of fuses (atc mini) (Mercedes)
3. On the left side of the drivers area next to the left foot of the driver is another set of mini ATC fuses. Mercedes
4. If you did not know, your Coach battery is at the rear of the Midwest UNDER the floor in front of the bumper and is accessed from underneath the Van. There are usually 2 Lifeline batteries and VERY heavy. If NOT Lifeline then somebody has changed to a different brand. Also, if NOT Lifeline, you have to make sure the Charger system(usually you have an Inverter/Charger) is set up to charge batteries that are NOT Lifeline. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
