dougrainer
Aug 08, 2021Nomad
1. IF the coach battery was GOOD, you could run the Microwave regardless of driving or the Genset
2. Solar ONLY really charges SLOWLY when you are stored. It will charge in use, but you will deplete whatever charging the solar supplies by using the Motorhome.
3. AS I stated. Get hold of Midwest. You have problems now, go to CW and you WILL have problems. They will NOT have anybody skilled enough to work on your particular motorhome.
4. The battery is NOT full. I don't know how you are determining it is full, but it is NOT. A BAD battery can show 12.1 and up volts, but that does not mean it is good. Look, you think you have a Lemon. You do NOT. Maybe the previous owner never got this problem fixed and sold it to you. BUT, get the battery replaced and the charge system fixed and you have a good motorhome.
5. Last, MY pet peeve;) You have a problem. You have NOT been able to get it to someone that knows what they are doing and now you complain about it being a Lemon. Lemons are when after NUMEROUS attempts at the same fix they never fix it.
6. Call Midwest at 574-522-4878 Ask for Brian or Kyle or Noy. Tell them you are just trying to find a Midwest Service center in your area. Last resort is, ask them if you drive to Elkhart, Indiana will they be able to look and fix. That means a 5 to8 hour drive depending on how far you are from Elkhart. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
