dougrainer
Dec 22, 2021Nomad
Just went back thru the previous threads. If you have NOT replaced the Coach Lifeline batteries, GET THEM REPLACED. No if ands or buts. Once Lifelines go dead, they are BAD. PERIOD. From your previous posts, the batteries HAVE at times been dead. Lifelines are NOT cheap, BUT they are the BEST batteries for your application and will last years if not allowed to go dead. If you go to another brand AGM battery, you will have to reprogram your Inverter/Charger to correctly charge other brand AGM batteries. Your Inverter/Charger was programmed by Midwest to correctly charge Lifeline brand batteries. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
