dougrainer
Jan 13, 2022Nomad
Grit dog wrote:
Since you're selling it, now, it is of little consequence, but to clarify, the inverter produces AC power in lieu of the other AC sources (genny or shore power).
Your rig is not or should not pull AC power through the inverter as a higher priority over the other 2 sources.
Also, no way I would buy the most expensive battery just to put a 4 sale sign in the window. My 2c
Correct. If selling install a Interstate 8D AGM battery. You MUST install an AGM battery due to its mount location. You cannot and do not have access for checking battery water. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
