dougrainer
Feb 04, 2022Nomad
Sprintervanmom wrote:
I’m sorry to frustrate you to the extreme, Doug. I did spend $1700 replacing the battery. It took time to find the battery because you encouraged me to get lifeline and I did hunt it down. They had to go through a third party to find the lifeline battery and I had to pay for it before it was installed. When they took the other battery down they said it was actually still good. Oh well.
I am selling the vehicle tomorrow though and after running the inverter with the TV for over an hour and boiling some water my issue is solved. I’m happy for the new owner. Thanks again for you help and sorry to cause you trouble.
They did NOT have to pull it to determine it was good. From all the posts you have posted, the battery was bad. After the New battery, except for the charge solenoid that was replaced, are ALL your problems gone? if so, the battery was bad. I am NOT frustrated. I was stating you were:B Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
