time2roll
Aug 06, 2017Nomad
Opened the booster lid today. There are four adjustment pots with easy top access.
I assume these are to adjust the set points for High Cut-off, Low Cut-off, Low Boost and High Boost.
Looks simple if I knew which was which. And I need a variable AC voltage supply to dial it in.
I see this Philmore 48-1205 $70 at Frys that I think will serve the purpose.
Any other ideas? Variac seems high priced for this project.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
