time2roll
Aug 06, 2017Nomad
wa8yxm wrote:Yes it is connected in the right sequence.
How are you wired
Post---Pi--Franks--RV (Wrong)
Post---Franks---PI--RV (Right)
The PI was not cutting power for low voltage. Franks Superautomatic was cutting power and the PI would then delay power from coming back on as normal. Franks would immediately turn power back on once the load was removed and voltage popped up a bit. This is actually a bad design issue with Franks as there is no delay to restore power and no spread between cut and reconnect.
Just read a post from Forest River forum that Frank Izbinski has passed away at least a year ago :(
I had bought mine direct from him about a decade ago. Picked it up at his home in the Los Angeles area.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
