time2roll
Aug 20, 2017Nomad
Tested the PI today to verify operations. Comparing with my Fluke meter the PI reads about 1 volt on the high side. Low voltage cut-off is right about 103.0 volts.
This confirms that it was the Frank's Booster that was cutting power too soon. Booster has now been adjusted to keep power on.
I know some think 103 is a bit low for cut-off however at this level things are fluctuating quite a bit and the voltage is not going to sit here for long. Will either pop up a bit or will trigger the cut-off and time delay. I like the way the PI works. JMHO
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
