wa8yxm
Jun 08, 2020Explorer III
BFL13 wrote:
Red (pos) and white (neg) load wires to the same post?
Thought that may be (Red and white to same post) be aware that The color of the wire is not standardized.. Black and White both have the same meanings depending on who put the wire in (I would make Black Negative since I'm DC trained) most RV bilders black is HOT. So do not trust colors. use our meter to find out.
Recetly 'Fixed' a very expensive bit of electroics by having the owner meter the incomig power leads.. RED was negative on the supply (RV) side. and on the electronics side red was Positive as it should be.
Your volt meter is your friend which is why I have a bunch of 'em.
