BFL13
Jun 08, 2020Explorer II
revcononthehill wrote:
Thank you for the excellent explanation.
So it sounds like I need to put the rest of the positives onto the one battery on the right and all the negatives on the battery to the left and use the jumper cables to jump them together. I’ll test the white one tomorrow to see what it is.
I put the batteries in the same way but am going to take them out so they aren’t reversed like that. Not sure why I did it like that again.
You reverse the batteries like that so it is easy to reach the two posts, now at the same end of your tray, the load wires go on. In that photo above, it looks like it would be easier to use the two posts at the bottom of the photo if the neg wires will reach.
With the batteries reversed, your parallel linked are crossed.
