OK so it is a WFCO converter and 30a GP solar controller.
WFCO should drop voltage to 13.2 after a few days of storage. Verify after five days as many fail to drop. Normal 13.6 could be a bit high for float for extended storage in 100+ temperatures. No real harm but watch the water.
GoPower will apply 14.4(wet/AGM) or 14.1(gel) volts for one hour each day before floating at 13.7 volts. This is too much and too high IMO especially for Tucson summers. Again watch the water level.
http://gpelectric.com/files/gpelectric/Docs/Manuals/Go_Power_MAN_GP-PWM-30_0.pdfMy recommendation is to upgrade the solar controller to a programmable unit with temperature compensation. Post how many watts the panel is and any plans for expansion for a controller recommendation.
