- boojsn2020ExplorerNice!
- DrewEExplorer IIIGreat! It's always nice when the problem is that simple and can be solved by flicking a switch.
- N-TroubleExplorerNo 12v power. You were right my batt cutoff got switched while genny was running. All good now thx
- DrewEExplorer IIIWhat do you mean by "all power" -- 12V power for lights as well as 120V power? If so, it sounds as though the battery disconnect swtich has been set to disconnect; once the generator shuts off, the converter stops converting and you have no 12V power available.
If you mean 120V power only, and you're plugged into shore power, it could well be the transfer switch failing to transfer back. If you're not plugged into shore power, of course the 120V power goes away when the generator shuts off....
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
