joebedford
Oct 21, 2015Nomad III
smkettner wrote:It runs to a 20A receptacle where the plug from the converter, well, plugs.joebedford wrote:As long as it is the actual wire off the appliance it is fine. If you need to extend the wire use #12.
BTW, the wire that goes off to the installed converter (100A) is clearly 14ga. The breaker is 20A - is 14ga enough for that?
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
