way-lou's avatar
way-lou
power plug
Power plug on dash not working checked fuse its ok is there any other fuse some were that could burnt out Thank You
  • Thanks I wanted to plug in my GPS it would not work in the plug it did work in the cigarette plug which is right below it
  • It may not be your power plug at all because the plug that you are plugging into the power plug could have an internal fuse in it. It's possible that the internal fuse is blown.
    OOOPPPS! INPUTTED TWICE.
  • Hi every one
    Thanks for your help but this plug did work the last time I took it out I am going to get the ground checked out I was hoping there would be a power fuse some were that I can not see
  • Some 12 VDC power outlets are enabled/disabled by the position of the key.
    You state you have power, is the ground wire attached and grounded???
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
